Field Map Guest Viewer role
131
a week ago
KyleKeath
Good afternoon all,
I hope this is something simple, that I'm just over seeing.
We have a Viewer User Type with a Guest role for a client just so they can view a map in Field Map.
I have created a group for this client, and only shared the features pertaining to that specific field map.
Here is my issue.
-Said client logs into FM with username/ password we supplied
-On initial view they only see that one field map I shared with them
-But if they have the gumption, they can use the search box by scrolling down. This reveals a few other maps we use in your organization. Yes, they need to start typing to find them, but they are there. This is less than ideal for my company.
I could use some help or explaining in this area. If this has been discussed before, just point to the right place. Hoping this is just a toggle somewhere.
Thanks all
CodyPatterson
MVP Regular Contributor
Hey @KyleKeath
We have a similar situation with contractors, in our case, we had to move organizationally shared items into their own high-level groups, this prevents them from searching, is this the same case you're having?
Cody
KyleKeath
@CodyPatterson
This sounds like the same issue. I'm pretty new to some of this organization stuff, as it currently got handed to me.
What are the high-level groups you're talking about?
Did that solve the search issue in Field Maps?
Kyle
CodyPatterson
Hey @KyleKeath
I apologize I use weird terminology, when I mention high-level it's just like a bucket group. For our construction crews, I have a bucket group named "Construction" and it just contains everything that people in construction would need. If I need to isolate a map, I assign it to only one group, and then the users to that group.
Removing the organizationally shared groups will solve the search issue problem in Field Maps, I think the only maps that appear would be the Esri world maps and so on.
Cody
