Edit vertices of existing features in field maps
1294
04-08-2022 08:40 AM
ChelseaVSmith
Hi all,
I'm using FieldMaps app version 22.1.0. I have a land parcels database which we're using FieldMaps to add new management activities too in with a related table. However I also need to be able edit existing land parcels as work is carried out.
Ideally I'd love to be able to edit existing features with coordinates but this only seems possible when creating new points.
As a work around I've created a point layer where users add in the coordinate points of where the existing feature service needs to snap too, but I only seem to be able to add another vertex not snap an existing vertex to the new point. Is this functionality - to edit existing vertices - available in FieldMaps yet?
Best,
Chelsea
aemacpherson
I have the same question. I found a video showing that you can click to select another vertex when editing but try as I might, I can't get any other vertices to highlight except the last one created!
