Can the Choice List in Field Maps Designer Forms use a subset of list values, removing unwanted values?
298
09-25-2025 01:07 AM
peterverwey_ses
Is it possible in Field Maps Designer Forms, to restrict the available choices for user selection from all available list values?
Example - Damage Assessment in Field Maps
When assessing whether a property is safe to access by the field worker.
Current list values are YesNo, and Undetermined.
I need to offer a field worker the option to choose between Yes and No, but without the option to choose Undetermined.
I need all three values in the list, but only two are valid inputs.
This is a simplified example, there are others where I might need to only offer a selection of 7 out of 15 list values.
I can't remove the list values in Field Maps Designer because that removes them from the domain in the feature layer, and there are calculations in the form that use some of the hidden values as valid inputs dependent on previous user inputs.
Any help would be appreciated.
Many thanks, Pete
