Can a Smart Form I configured be saved as a file?
2196
5
10-02-2023 07:47 AM
StaciMcLaughlin
I have been working on configuring Smart Forms for Asset Inspections in my Web Map. I was seeing if there was a way to save the form as a file. This way I can bring this way I can copy the file location into an existing script.
This is an example of one of my forms below:
 Thank you!
JustinReynolds
Hi Staci,
It is definitely possible.  We save all of our forms as JSON files and maintain them in using Version Control (GIT).  There is no button that will enable you to export to a file.  There are two ways that we go about it.
  1. Using ArcGIS Assistant we can access the JSON of a web map or layer, then we copy and paste into our file... in this case a JSON file.
  2. Using the Python API, you can access the map or layer definition and pull out the Form JSON and save it to a file.
Our standard workflow is to create a template form using Field Maps Designer, save the from to a JSON file in a code repository, then any time we publish a feature layer to AGO or AGE from a template we then use the ArcGIS Python API to apply that template Form.
- Justin Reynolds, PE
JustinReynolds
Hi Staci,
StaciMcLaughlin
This is great, thank you! I was able to save the form to a JSON file using Visual Studio Code. I appreciate the quick responce too!
DougBrowning
Good Idea.  This would be handy to build 1 form then reuse it for each of our 11 states.  Would also be good for backups.  If we lose a map now we have to start all over.  Also would be great to reuse the form for the next year of collection vs having to start from scratch.
Depending on your use case the save to the layer option may work for you.  Then the form is with the layer vs the map.
AH2
@DougBrowning Do you know how to copy a form from a web map that uses one feature service to a new web map with a different feature service?  We are using ArcGIS Enterprise and feature service is created from Oracle database (so not hosted feature layer).
I created a new post here (https://community.esri.com/t5/arcgis-field-maps-questions/copy-forms-to-new-web-map-in-arcgis-field-...)
DougBrowning
Have you tried AGOL Assistant to see if you can swap out the data source?
