Bug? Field Maps no longer displaying labels for online and offline areas but did yesterday.
670
09-04-2024 03:25 PM
LayerItOn
Bug?
Field Maps no longer displaying labels but it did yesterday. Yesterday it displayed for the online and offline maps. Today it is not displaying for either. However, it does display correctly in the Map Viewer. I also checked the visualization for each individual layer and labeling is enabled (as was the past workaround for a similar issue on this post: Labels Are Not Displaying in Field Maps).
I have recreated my offline areas but I am still experiencing this issue. Any ideas on how to get it working again? I am guessing this is a bug?
Update: Tried to recreate my offline areas again and now getting a "failed to fetch" error. Even when trying to create a new offline area. Perhaps this is part of the reason why my labels aren't displaying.
DanielFox1
Hi @LayerItOn
Sorry to hear that you are experiencing this. As per the post you referenced it looks like the bug mentioned in that post.
Are you able to remove any configuration set up within the visualisation tab?
or
Have you tried to follow the other accepted solution in the post you linked to?
