Are subytypes/subtype group layers in related tables supported?
175
11-06-2025 02:47 PM
JulietteG
I have an ArcGIS Online Field Maps application that has a list with over 100 choices.  Are subtypes supported in related tables?
The Field Map does not require features (points) since it will be used in one location.
JamesMiller36
In ArcGIS Field Maps, subtypes are only supported on feature layers, not directly in related tables. For your use case, you’ll need to handle the related table choices manually or via a hosted feature layer that includes subtypes, even if you’re not collecting spatial features.
