Arcade Expressions Wont Calculate
263
05-15-2024 06:45 AM
DaveK
Hello!
I'm creating a Field Maps app for data collection. I have a unique ID field that I would like auto calculated based on the time down to the millisecond. I'm using an Arcade expressions for this. The Now() function doesn't get does that far but if I use Time(Now()), then I do get milliseconds. Unfortunately, this function as well as many others don't see to calculate in the Field Maps app. Is this typical behavior? Should I be formatting my Arcade expressions in another way to allow them to work? Any help is appreciated.
Thanks.
ChrisDunn1
Hi @DaveK ,
The Time() function is not yet supported in Field Maps, it will be in a future release.
In the meantime, you can format the timestamp to get miliseconds using:
return Text(Now(), 'dddd, MMMM D, Y @ h:m:s:SSS')
Note that the "SSS" for milliseconds is case-sensitive and needs to be capitalized.
I hope that helps!
Chris
