Arcade Expression works in Field Maps app but not in Forms Map View
152
Friday
KristenKlaphake1
Hi all,
I created an Arcade expression using the Field Maps Designer 2 days ago (10/22/25). The arcade expression creates a unique id based on the initials of the user and getting the latest object id as a starting counter plus 1.  This worked when I tested it in the Field Maps designer map and also in the FieldMaps app. This expression functions in an offline scenario.
Today I added a new record in the Field Maps designer map and the record did not populate, although the "Create Features" display box shows the value, once I click "Create" no value is transferred to the record.  When I run the same map in FieldMaps the value is populated correctly.
Help, am I crazy?
Here's my code:
if(!isEmpty($feature.WaypointID )){
  return $feature.WaypointID
var userInfo = GetUser($layer);
var numberlist = FeatureSetByName($map,"Waypoint")
var topnum = Top(OrderBy(numberlist,'OBJECTID DESC'),1)
var counter = Number(Max(topnum,'OBJECTID'))
var id = counter+1
return Text(left(userInfo.username,2) + "-" + id);
peterverwey_ses
EDIT .. re-read your post and the app is working, but the Map Viewer is not. Oops.
Hi Kristen,
What version of the Field Maps app are you using?
I have found that versions below 25.x don't follow all the Field Map Designer's settings.
Pete
KristenKlaphake1
Hi Pete,
I am using Field Maps version 25.2.7.
My arcade expression works in the Field Maps app.
I developed the code in Field Maps designer and it populated the records accurately early last week and now it won't populate the records using the same code.
Kristen
DougBrowning
MVP Esteemed Contributor
KristenKlaphake1
Hi Doug,
The funny thing about this is that it works in the Field Maps app, but not in Field Maps designer, although I originally developed it in Field Maps designer where it did work for me early last week.
Thanks for you input
Kristen
