So we are trying to get a start on migrating from Collector to Field Maps and are setting up our first map. We have an editable hosted feature layer, a template is set, the form is configured, and yet when we hit the '+' button in Field Maps it says 'No Visible Layers, Use the layer tool to toggle visibility'. However the layer is turned on and I can see, click on, and edit existing features. Any idea what I'm missing?
Hi Jason, I was wondering if you are able to share your web map with me? If you prefer too you can email it to me at apower@esri.com and we can communicate over email.
Hi, Jason, can you add new feature to the same map with Collector? Can you try a map that works in Collector with Field Maps?
