Show which users have an offline area downloaded
696
06-28-2023 01:41 PM
Status: Open
L77
It would be nice in Field Maps Designer to be able to see which users have an offline area downloaded in the designer section of each map.
1 Comment
DougBrowning
Just saw the new version of Pro will have it.
For now I am using a python script to make a report.  As long as Pro is logged in it will grab the credentials from there.  it gives the username and last date, etc.
# gets a list of replicas for a given HFS (hosted feature service)
import arcpy
from arcgis.gis import GIS
import arcgis
from arcgis.features import FeatureLayerCollection
gis = GIS('pro')
#gis = arcgis.GIS(profile_name=profile)
#itemID of service
# Lotic
itemID = "713e3aaef967447d618"
item = gis.content.get(itemID)
flc = FeatureLayerCollection.fromitem(item)
replicas = flc.replicas.get_list()
print ("ReplicaOwner,ReplicaName,ReplicaID,CreateDate,LastSyncDate")
for r in replicas:
    replica = flc.replicas.get(r['replicaID'])
    create_date = datetime.datetime.fromtimestamp(replica['creationDate'] / 1000)
    last_sync_date = 'n/a' # don't trust this to always be populated
    if type(replica['lastSyncDate']) is int:
        last_sync_date = datetime.datetime.fromtimestamp(replica['lastSyncDate'] / 1000)
    print(replica['replicaOwner'] + "," + replica['replicaName'] + "," + replica['replicaID'] + "," + str(create_date) + "," + str(last_sync_date))
You can take the output and paste into Excel.  (sorry was just a quick script you could add to a csv right away)
I also have a script that takes a list from this and will unregister in bulk
# Unregisters a list of given replica ids - usually from the List replicas script
import requests, arcpy
# sameple  https://services.myserver.com/lidGgNLxw9LL0SbI/ArcGIS/rest/services/SaveTheBay/FeatureServer/unRegisterReplica?replicaID={b7b70c50-7b8d-4938-a6f9-61f376e94c75 }
# read in the list of replcias to remove from file
replicaFile = r"ReplicaListBeforeJuly15.txt"
replicaRead = open(replicaFile,"r")
replicaList = replicaRead.read().splitlines()
replicaRead.close()
print ("Read in list")
# base URL to the HFS
serviceURL = 'https://services1.arcgis.com/Hp6G80Pky0om7QvQ/arcgis/rest/services/youragolserviceService/FeatureServer/unRegisterReplica?replicaID='
token = arcpy.GetSigninToken()
##if token is not None:
##    print(token['token'])
for replica in replicaList:
    print ("Removing Replica " + replica)
    urlResponse = requests.post(serviceURL + "{" + replica + "}&token=" + token['token'])
    #print(urlResponse.text)
 I use this to unregister old replicas on the regular.  As we get more and more it gets unreliable.  We keep having old ones since there is a bug in Field Maps that if you remove an offline area while offline it never tells the service to remove the replica.  You can see it fail in the logs.  I told the team but I do not think it ever got fixed since they think it works but I showed it does not.
Hope that helps
