Setting the date field to today sets the date without user interaction
12071
32
06-10-2021 01:52 PM
BenWalker1
If I have a field, like a survey creation date, it should possible to set it to be today's date without the user needing to open a separate dialog box and then confirm todays date. this will reduce the number of clicks the users needs to have with the form.
Tags (1)
32 Comments
ADS
Thank you @JustinReynolds !
BronwenHughes
@JustinReynolds   - thank you for that code.
When I add it to the form in Field Maps, the field becomes un-editable. It appears that if a "calculated value" is applied to the Date field, then editing capability is switched off.
Is there any way to get around this?
I would like the date to default to Now, with the option to change to another date as required.
