To make the already great FieldMaps even more amazing
FieldMaps gets the GNSS metadata from NMEA and stores it in the Field. But there is no freedom. Our users’ usage should be diverse.
I want to select the type of data I get from NMEA and the calculation method. Or I think it would be more user-friendly if I could define it with Arcade expressions or something like that.
Thank you for reading. I hope you kudos with me if possible.
