I would like to use FieldMaps to survey Points using GNSS equipment. My job requires averaging of points, number of satellites, PDOP, etc. FieldMaps does not allow me to get the number of satellites when averaging, but a single point does. It would be great if the minimum number of satellites and the maximum PDOP could be recorded when averaging.
