Auto populate the old inspection records from the related table while doing new inspection using field map to edit related table.
I wish I could upvote this 100 times. I've seen the videos that show how you can configure historical data but getting the end user to use it as it's shown could prove to be a huge challenge. I know there is a copy and paste method that can be used to accomplish this but consider quickly growing departments...If the copy and paste part of the workflow is lost in translation, a lot of data will be deleted. A button or some sort of back end set up where the current record auto-populates into the related table/historic record table would be extremely helpful.
