It's often the case that field workers fill text fields with identical text patterns. It would be helpful to select pre-defined text modules and fill them into text fields. User can edit or append.
Advantage:
* User is faster than typing on the mobile keyboard.
* Similar results
* no need for related tables just for informational "multiselect" information
