I have multiple clients that I work with, but they all utilize the same local base maps from the county. I created a general Base Map that was then placed into the Base Map Gallery through their AGOL accounts. The Base Map itself was a link to the county image server. Worked great until the county changed their image server. How do I either delete and then replace the new link, or get into the current Base Map and just update that link?
