Unable to add local intra net services
1983
03-18-2013 04:44 AM
PramodHarithsa1
I have used my local intranet services on http://www.arcgis.com/home/ successfully and created my own maps out of them!
and when i try to open them using explorer online it shows a red exclamation point, and on hover I see text that says �??The source for the layer is inaccessible�?�.
Searching in forum for a similar issue i found this thread
http://forums.arcgis.com/threads/30923-Unable-to-see-services-or-content-in-ArcGIS-Explorer-Online-b...
But the  clientaccesspolicy.xml file that the thread suggests is present in the system where the services are hosted.
So what am i missing here??
<EDIT>
The service is hosted using ArcGIS server for Java. (uses inbuilt tomcat server)
The service url looks like this http://myserver:8399/arcgis/rest/services
I added the clientaccesspolicy.xml and crossdomain.xml at this location
C:\Program Files\ArcGIS\Server10.0\java\manager\service\managerserver\webapps\ROOT
After doing this i don't see http://myserver:8399/clientaccesspolicy.xml link working
Have i placed the files at the right place for things to work?
</EDIT>
PaulLohr
Did you verify that the REST endpoint is accessible?
Example:
http://www.someorganization.com/arcgis/rest/services
If you have a way of testing this from outside your network, it is better because you will see what users outside your network will see. A USB cellular modem works well or an iphone or android phone's browser. Or ask a friend who is outside your network to check the REST endpoint.
Paul Lohr
PramodHarithsa1
Example:
Paul Lohr
Hi Paul,
The rest endpoint isn't hosted globally. Its available only in intranet.
The problem i have is ,
i am able to create a map using the rest endpoint in arcgis.com but when i open the same in explorer it doesn't work.
