We have field crews using Collector/Explorer who would like to be able to dynamically filter down large datasets through the apps based on their work area for the day, rather than having to go into the web map thru the basic map viewer beforehand each time. For example, say they're doing facility inspections though Collector or an Explorer/Survey123 combo, and decide that they'd check all facilities within zip code "X" one day, and then zip code "Y" the next. Filtering them down so they can easily see where to go next and and avoid duplicating work with another crew working an adjacent zip code, would be very helpful.
I cannot believe they do not have this basic functionality...
