I have a map with a point layer of service addresses (points). When I select one of those points in Explorer it returns an "address" below the primary display field in the results pane. I suspect it is a geocoded address, however, it is confusing because it is often not the real world address.
The behavior in Collector shows coordinates below the primary display field in the selection details pane. I would rather have the coordinates displayed than an incorrect address.
