Hi,I have an application that is composed from a dock window and an extension. At the onStartUp event of the Extension I am adding my own layers. The client requested that this Application should always open with a specified extent. I tried this code in the OnStartup event: ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay.ZoomTo(new Envelope(27.0035540404876, 15.2397874917475, 56.8697829519645, 31.6822644786311), 800000);
but id did nothing. If I place this code insite the dock window it works fine, but the problem is that I can't do this because I can't be sure that onStartup of the application the dock window will be open. Is there a way to do this?Thanks
