Is posible to extend a layer from arcgis explorer API, so I can set an image that shows a heat map, I can create the Image, this image contain the hot heat that is built using data(coord x and y) from web services but how can I show the image on the map?, I' am using an example that works fine in silverlight, but I'd like this funcionality on Arcgis explorer 1200, Thanks.
