I'm adding content to AGX Desktop from an ArcGIS Map Service published from an .mxd, the source data is SDE, ArcGIS 10, AGX Desktop build 1750.
If in the .mxd file I right click the layer set the properties of Scale Range on the General tab to anything other than "Show layer at all scales" - then when I add that service in AGX Desktop I'm unable to access popup data by clicking on an object - nothing happens.
I've tried it a few different ways, and it seems if whenever I set a layer scale range, somehow this disables popups when referencing this layer in AGX Desktop. This is a problem because I'd really need to be able to set scale ranges for my layers.
Can someone from ESRI please test and advise?
Thanks!
