ARCGIS Explorer Desktop Symbols
2041
04-01-2014 09:46 AM
CameronDodds
I use ARCMap desktop to create Layers packages. I then provide client with those layers. They use ARCGIS Explorer to view those layers. The symbols for those layers are different than the ones I used on ARCMap Desktop. They show up as letters or numbers etc instead of Esri Symbols. Can you assist?
JoeFlannery
The AGX 1750 website has a Fonts Expansion Pack download located here:
http://gisupdates.esri.com/ArcGISExplorer/Build1750/ArcGISExplorerFontsDownload.EXE
See if this helps your end-users.
CameronDodds
I will see if that helps. Thanks Joe. I will let you know.
CameronDodds
The EXE kept saying that it couldn't find an ArcExplorer Desktop version on the PC. I was able to go to ARCGIS Explorer Options and install the Expansion Pack for the Fonts. It now works. Thanks Joe.
