can i use ArcGIS Explorer 1500 with ArcGIS Explorer Data Access Expansion Pack to make a direct connect to a 9.2 ArcSDE géodatabase (on sql server) ?
I currently have this error Message "Failed to connect to <USERNAME>."
I've checked the connection informations was the same as used in ArcMAP with "GDB Direct connect" :
Geodatabase type: ArcSDE Geodatabse
Server: Myserver name
Service: sde:sqlserver:MyServerAdress
Database: MydatabseName
using database authentification Username/Password
Regards,
Erwan
