OPen .pmf files in ARCExplorer 1500
5657
9
03-17-2011 01:59 PM
MikeSpedden
Is there a way to open (or convert??) .pmf files in this program?   Thanks!!
MikeSpedden
anyone ????
PatrickTaurman
PMF files are used in ArcReader.  I don't believe there is any way to "convert" them.  ArcReader is a free download though, so I would use that to view these files.
MikeSpedden
Thanks for the note...however, i need to edit the files.....
AndreiIvanov
You cannot open PMF files in ArcGIS Explorer.
DavidBlehm
can the data behind the pmf file be read or transulated?
Robert_LeClair
Esri Esteemed Contributor
Depends on the *.pmf author.  In ArcMap and using the Publisher toolbar to create the *.pmf, the author can create a data package in a separate location from the original data.  For the data format in the Data Packaging wizard, the *.pmf author can select File Geodatabase, Compressed File Geodatabase, Compressed and Locked Geodatabase, or Copy data in existing format.  If the *.pmf author selects File Geodatabase for the data package for the *.pmf, then a user with ArcMap could edit that data (but could edit the data using ArcReader).
Hope this helps.
Regards,
Robert LeClair
Esri-Denver
AnthonyDunk1
A tool called PMFInfo.exe comes with ArcReader10. Info about this is here:
http://edndoc.esri.com/arcobjects/9.1/ArcGISDevHelp/DeveloperTools/PMFInfo.htm
SharonH
Hi
The compressed and locked geodatabase is not working in the Publisher extension for Arc 10.1.
Is this a bug?
Can it be fixed?
Thanks
Sharon
MarkBockenhauer
It works in ArcGIS 10.2
Mark
