Hey All,
I'm trying to get AGX to fully run off a USB stick. I have a custom configuration that uses custom built addins and my own default map. So far I can get the custom configuration to load by running E3.exe with the appropriate /AppConfig switch, but I still have two issues:
1) I can't seem to get it to load my default map (TCGSAR.nmf)
2) When e3.exe runs, it puts a whole bunch of files into $User$\AppData\Local\ESRI\ArcGIS Explorer (i.e. the default windows 7 path for user data)
How do I give AGX a specific (relative) user data path and have it load a specific .nmf file on startup? Remember that AGX is not actually installed on the computer, so I can't just click on the .nmf file. Is there something in the settings1500.xml file that I can change?
Speaking of which, can any of you helpful ESRI engineers tell me the structure of the settings1500.xml file and what all the possible options are for it?
Norman
