My work around is to change the 'Refresh Options' for the particular problem layers.
-Rick
In the old forums, I found a solution for this issue. They suggested exporting the shapefile to a new shapefile (right click --> data --> export). This fixed this issue for me. Hope it helps. Adam
I've also had the exact same problem but seem to have found a means to work around it. I'm using Explorer build 1500. In my current case the failing layers are layer packages (.lpk) built in ArcGIS 10. I've also watched it happen last week in shapefiles and FGDB feature classes. Only two out of several layer packages are experiencing this issue in my current Explorer project. They work fine for a while panning and zooming, but it seems that once the cache for these particular layers gets to a certain size of around 2mb they start to fail in the map (I've been watching the file sizes in the default cache directory C:\Documents and Settings\...username...\Local Settings\Temp\E3).
My work around is to change the 'Refresh Options' for the particular problem layers. Go to Layer Properties, Source Data, and choose the radio button for "At a specific time interval". It doesn't seem to matter what time interval you set. I tried "1 hour" and also "1 minute" and both worked immediately to solve the problem. You need to save the your project for the setting to take effect permanently.
As a side note...It seems like the refresh option for "When the map is opened or the layer is added" would similarly solve the problem but it does not. That option apparently has a bug. See this forum http://forums.arcgis.com/threads/15362-Help-me-understand-caches-and-refresh-options?highlight=explo...
-Rick
We have had the same problem with some of our data diss-appearing as well. I have all data setup to stream layer packages. Mainly sections of a TMK layer will just not draw at certain zoom levels. Our solution for the time being was to train the users on how to "right click" the data in the contents window and just refresh. Seems to work for us for the time being. I'm assuming this clears the cache for the data being refreshed.
Although time has passed from the last posting, I wished to provide insight. Under C:\Documents and Settings\[username]\Local Settings\Temp, the A3 folder contains the caches that need to be purged on a regular basis, especially if the same default map or AGE project is opened time and again. By not clearing the cache, the feature class/layer symbology [not labeling] will disappear.
As a resolve to the matter, I use a .vbs script that purges all of the C:\Temp folder when a user logs in and for those, that rarely logout during the day, a desktop shortcut to purge as needed during the day. I have also upgraded from AGE 1200 to the latest version 1500.
Hi Dustin,
thanks for the suggestion for refreshing the layers. This is still not working totally properly for us. How large are your datasets and how many layers do you have in your map?
I'm wondering, when you say you are streaming the layer packages - where are you streaming them from? local C drive? network? server?
thanks!
Sarah
The main .lpk we have problems with is 11MB TMK which is the largest since we have attached tabular data to it. All the rest are mostly under a 1MB. We are displaying about 27 .lpk's at once. I have all of the .lpk's on a network drive. I publish the map and upload to Argis.com "Groups" which I then download to each PC with the same access to the network drive. Works great aside from the occasional draw issue.
Hi Dustin,
yeah that's a lot of layers and data. do you have an SDE server you could save the data to? or have you tried saving it on your users' local machines? how many users do you have?
I reduced the number of layers in my map (although users can still add them through 'add content') and have all the data stored on each user's C drive - we have 12 users. I know this is not the best solution (I would prefer to save it on a server - we're working on that) but I found working with the data on the network was really slow. I guess it all depends on your organization's network latency.
So you're using ArcGIS Explorer Online? sounds like a great idea! I didn't know you could do that and still use local data.
