Widget Columm not srollable
163
11-23-2020 07:10 AM
MatthiasDufour
New Contributor III
Hello
I imported my Experience made with ArcGISExperienceBuilder 1.1 (Developer Edition) into ArcGISExperienceBuilder 1.2.
I have a widget "Column" including widgets "Text" (1) "Image" (2) and "Feature Info" (2).
The "Scrollable" parameter is activated (see image).
My problem is that the elements of the column remain fixed, whereas with version 1.1 there is no problem and the column is scrollable (see video).
Is it a configuration problem or a bug?
Reply
DavidMartinez
Hi Matthias,
Can you share your config.json with me please in a private message? I wasn't able to reproduce your issue.
David
Reply
MatthiasDufour
New Contributor III
Hi David,
I just sent you my config.json file as a private message.
Reply
