Map Widget Not Showing Organization Basemaps
364
7
01-25-2021 12:25 PM
GregoryBacon
I've enabled the basemap tool for a web map widget but our organizations basemaps don't show up as choices. I have a basemap group configured for our organization and other web maps/apps show my custom basemaps without issue. I'm seeing this in 10.8.1 portal but not AGO.
JenParkhill
Just closing the loop, this has been resolved in 10.9 Enterprise
From https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEzNDE5MQ==
BUG-000134191
Synopsis: In ArcGIS Enterprise, the Basemap widget of ArcGIS Experience Builder does not list the custom basemaps defined in the portal.
Bug Number:     BUG-000134191
Submitted:         Sep 29, 2020
Modified:            Mar 23, 2021
Severity:              Medium
Applies To:          ArcGIS Enterprise
Version Found: No Version Found
Prog Language: N/A
Server:                 Windows 10.0 64 Bit
Client:                   Windows 10.0 64 Bit
Database:            N/A
Locale:                  N/A
Status:                  Implemented
Version Fixed:   10.9
SP Fixed:              N/A
JenParkhill
We're also seeing the same behaviour (Portal 10.8.1). Hopped on here hoping for an answer or workaround.
Did you resolve this? If not, I'll submit a ticket with tech support.
GregoryBacon
I did not find a resolution to this yet.
DaveFullerton
Occasional Contributor II
I am experiencing this problem with the Developer Edition v1.3, not in Preview, but when I deploy it to the production server.
JenParkhill
Just following up with this.
It's a known bug (BUG-000134191) and is in the current product plan for Experience Builder, so hopefully resolved in a future release soon.
GregoryBacon
Thank you for following up. You beat me to the Tech Support call.
Grant-S-Carroll
I experienced the same using ExB Dev Edition against Enterprise. I worked around it by creating my own basemap widget which will only pull in the organisation basemaps. Code attached if anyone wants it, it s basically the JS API basemap widget with a call to get the organisation basemaps, have not tested it against AGOL.
JenParkhill
BUG-000134191
Severity:              Medium
Prog Language: N/A
Database:            N/A
Locale:                  N/A
Status:                  Implemented
Version Fixed:   10.9
SP Fixed:              N/A
