Map select tool limited to 100 features?
96
a week ago
Len
After adding a map to an Experience Builder app in the online geoportal and enabling the 'select' tool for the map, when I view the published app I am only able to select a maximum of 100 features with the select tool. Is this a default setting and, if so, can I change it somewhere?
Len
DavidMartinez
Hi Len,
In the Data panel for your feature layer, you can change the data settings to increase the record page size for the data. By default, it is set at 100.
Cheers,
David
DavidMartinez
Hi Len,
Cheers,
David
Len
Ah, excellent, found it! Thanks, David!
