Long text with "Window" functionality
851
07-06-2020 07:31 AM
MatthiasDufour
New Contributor III
Hello
I have a problem with the "Window" functionality.
There is no scroll bar in my text widget in "preview" mode. If the text is too long, it is truncated.
To see the end of the text, click on a button with three dots which opens a tooltip containing the text with a scroll bar (see video).
In "builder" mode, the scroll bar appears, but the text is fixed.
Is this a bug or the normal behavior of the widget?
Tags (1)
shaylavi
Hi Matthias,
You can wrap your text in a column container, which will then give you the scrollable option
Shay.
Shay
shaylavi
Hi Matthias,
Shay.
Shay
SIG1SMAAG
New Contributor II
Hi Shay,
Thank you very much !
It is perfect !
Matthias
