list widget not available when adding a trigger/action to map widget
732
03-17-2021 10:47 AM
Labels (2)
EdDean
I am trying to add a trigger to my map widget, so when a user zooms in only the points in the current extents are listed in the list widget. However, when I try to create this action the list widget isn't listed to select.
Here is a video showing what I see when I try to create this action.
Thanks in advance,
Ed Dean
DaveFullerton
You would want to take Action on the Dataset.  Try clicking on Framework:
Then Filter Data Records
And then hit Select Data to select the data you use with the List and Map
DaveFullerton
EdDean
Thanks Dave!! This solved the issue.
