Layer List in Experience Builder not working
2959
7
10-13-2020 02:31 PM
MarcoPoetsch
Occasional Contributor II
I came across an issue with the Layer widget in experience builder. When I run off a layer and close the widget, it won't show any layers again. Also, the actual map is not working anymore.
This happens if I use an ArcGIS REST Services  10.5.
DavidMartinez
Hi Marco,
Is this a map service with sublayers? If yes, we fixed this issue and there should be a new update in the next 24 hours. I am curious to see if it works on your side because in our requirements we state the services have to be at least 10.6
David
DavidMartinez
Hi Marco,
David
MarcoPoetsch
Thanks @David, I just did some more investigation and wanted to to give an update that this appears only on services with sublayers.
So yes, that's the case.
Sounds good. I'll try again tomorrow or so.
MarcoPoetsch
Hello David,
have you applied the update? If so, I can confirm that unfortunately it\s not working fro 10.5.
Cheers,
Marco
JamesBlouin
Hi Marco - I'm not an Esri employee but wanted to chime-in. Was your map created in Map Viewer or Map Viewer Beta? I ask because I had some glitchy issues with pop-ups, clicking and selecting items on the map, and the map losing its link (like your example) when I used a map created from the default Map Viewer.
I then opened my map in the Map Viewer Beta and saved/saved-as the map to the Map Viewer Beta format and it fixed all my issues in Experience Builder. My guess is that there is an issue with ArcGIS app compatibility when using older apps and newer apps. The Map Viewer uses ArcGIS API for JavaScript 3.x, whereas Experience Builder and the Map Viewer Beta are built on JavaScript 4.x.
I found these links helpful:
Apps that use ArcGIS API for JavaScript 3.x vs 4.x:
 https://community.esri.com/docs/DOC-14455
Compatibility Guide for web maps created with Map Viewer (classic) and Map Viewer Beta:
 https://community.esri.com/docs/DOC-14312
MarcoPoetsch
Thank you James!
That's very interesting and very good to know.
I did in the Map Viewer, since the Map Viewer BETA had some other limitations.
The ESRI dev team applied some changes yesterday, and the issues my app hat seems to be resolved
Jianxia
Marco,
The update just went out at 9 pm PST last night. Could you help check again?
MarcoPoetsch
Hello Jianxia Song‌,
yes! I can confirm, it it's working now for 10.
Well done!
Thank you,
Marco
