I am new to Experience Builder and would like the current local date to appear in a text box. The idea is the map displays current survey day results for surveys and then another page displays all surveys, so the '3/2/2021' would update dynamically each day.
Is there a way to accomplish this? I'm not seeing an option since its not directly linked to selected data.
Thanks in advance,
Kathy
Hi Kathy,
You could use the embed widget and use code to show the current local date of the client browser. For example, something like this:
<!DOCTYPE html>
<html>
<style>
body {
font-family: Avenir Next;
</style>
<body>
<p id="t1" style="color:rgb(230, 107, 0); "></p>
<script>
let today = new Date();
let date = (today.getMonth()+1)+'-'+today.getDate()+'-'+today.getFullYear();
document.getElementById("t1").innerHTML = date;
</script>
</body>
</html>
Hope this helps.
Cheers,
David
Hi Kathy,
So in a text box, you just want it to show the current local date of the client browser?
David
Hi David,
Yes to show the current local date of the client browser. I think this would be fine. The associated map will hopefully be showing survey data for the local day.
I appreciate any ideas you might have. I'm trying to figure out the best way for the associated map to also have a dynamic date filter on the layers too to only be showing data from local date and in our case AK time zone.
Thanks much,
Kathy
Hi Kathy,
<!DOCTYPE html>
<html>
<style>
body {
</style>
<body>
<script>
</script>
</body>
</html>
Hope this helps.
Cheers,
David
Hi @DavidMartinez ,
I just tried the embed and your code above. It worked, amazing!! Thank-you so much!!!
