Dynamic Content Expression
167
5
2 weeks ago
Highlighted
Trying to have text that counts the number of records in a database in which a specific attribute is "Yes".
What formula do I need to enter into the Expression box, so that if 3 of the 5 records have "Yes" for a specific attribute, then the number displayed is "3"?
Reply
Highlighted
Hi Jason,
You can create a View of your layer within Experience Builder and filter to only the ones that say Yes. So, in the expression box you insert Count() and select which view the data is coming from, if it's default or the data view you created:
Create the Data View here:
Select the Data Views when you connect the widget to data
Insert COUNT() and select whitch data view it's counting from:
Let me know if this helps.
Best
Highlighted
Hi Jason,
Best
Highlighted
Awesome, thanks!!
Is there, by chance, a way to perform a calculation to show the feature count, that has the attribute as "Yes", as a percentage of the total features in the database?
Highlighted
There is. You can add COUNT()/COUNT()*100, and select the data views for each COUNT(). However the result has lots of decimals and I don't know how to change that
Highlighted
Thanks again!!
haha, yea, need to figure out a way to format the text to limit the decimal places!
Highlighted
Is there a way to do any conditional formatting?  If the expression resulted in a value 50% or more, could you format the text to be bole red, otherwise it remains the default?
Reply
