Change layers shown in initial map view
1071
10-21-2020 01:07 PM
StefanieWenker
I have one webmap that I would like to support several experiences so that I don't have to maintain a separate webmap for each experience, but this also means I need different layers to be turned on when the experience first opens. Is this possible using url parameters or otherwise?
ShengdiZhang
Hi Stefanie,
You can do this with the following steps:
1. Add webmap, and open Data panel on the left side
2. Click the data you added, then you can see layers of the webmap
3. There is a "click to hide" button on each layer pane, click the one on the layer you want to hide
Note: when you hide a layer, all widgets in this application cannot use data from it.
Hope this helps.
Shengdi
ShengdiZhang
Hi Stefanie,
Hope this helps.
Shengdi
