Bug? - Map Tools not available after switching View/Section
1186
10-21-2020 08:16 PM
MarcoPoetsch
Occasional Contributor II
Hello,
I found an issue which is quite annoying for me. Maybe there is an easy fix for that?
The problem is, if I switch the view/section from one to another, all the map tools (search, basemap, navigation,...) disappear and are not available anymore.
However, this happens ONLY if I define a map action (Extent Changes - Zoom to). So, it works fine if no map actions are setup..
First initial view is fine:
But changing view results in:
Also: Very interestingly, this does not happen in the Live View.
This is my setup:
for all maps:
Cheers,
Marco
MarcoPoetsch
Just discovered that, it works also in draft mode.
So it's just not working when published.
DavidMartinez
Hi Marco,
I just tried to reproduce and I couldn't. Can you share your experience with me? My username is dmart.
David
MarcoPoetsch
Thanks, I have sent you the invite.
The behavior is a little bit inconsistent. So for instance, I could start the Experience and go to view #2 which has then the issue with no map tools showing. All the other views are working fine. When I refresh the Experience, #2 might work this time, but some of the other don't.
I tested on Firefox and Chrome. None of them show any issues in the console.
MarcoPoetsch
sorry to be a pain, but I just discovered another odd behaviour.
I have added another service to the web map, this time from a different server (10.6.1). This service had limited access, and therefore I was asked to signing. After signing, however,:
  • none of the map tools were showing, and
  • the map actions (Zoom to) weren't working
MarcoPoetsch
I have removed the layer from the restricted service, but I'm still experiencing issues:
In case it helps:
  • The maps are build in the classic MapViewer
  • All layers inlcudeng the basemap are from an ArcGIS server 10.5
  • Spatial Reference: 2193
