I'm trying to start up the Experience client but I'm getting the below error. I am using Administrator rights on the cmd, and I don't have any custom widgets in the build. Please advise.
> exb-client@1.2.0 start C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client
> cross-env NODE_ENV=development webpack --mode development --watch
C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack-cli\bin\cli.js:281
throw err;
AssertionError [ERR_ASSERTION]: ArgumentError: HappyThreadPool requires a positive integer for its size , but got {0}.
at HappyThreadPool (C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\happypack\lib\HappyThreadPool.js:38:3)
at HappyPlugin.apply (C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\happypack\lib\HappyPlugin.js:76:47)
at webpack (C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack\lib\webpack.js:51:13)
at C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack\lib\webpack.js:36:39
at Array.map (<anonymous>)
at webpack (C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack\lib\webpack.js:36:24)
at processOptions (C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack-cli\bin\cli.js:272:16)
at C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack-cli\bin\cli.js:364:3
at Object.parse (C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack-cli\node_modules\yargs\yargs.js:576:18)
at C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack-cli\bin\cli.js:49:8
at Object.<anonymous> (C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack-cli\bin\cli.js:366:3)
at Module._compile (internal/modules/cjs/loader.js:1063:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
at Module.load (internal/modules/cjs/loader.js:928:32)
at Function.Module._load (internal/modules/cjs/loader.js:769:14)
at Module.require (internal/modules/cjs/loader.js:952:19)
at require (internal/modules/cjs/helpers.js:88:18)
at Object.<anonymous> (C:\Users\Anneley\Documents\ArcGISExperienceBuilder\ArcGISExperienceBuilder\client\node_modules\webpack\bin\webpack.js:156:2)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
at internal/main/run_main_module.js:17:47 {
generatedMessage: false,
code: 'ERR_ASSERTION',
actual: false,
expected: true,
operator: '=='
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! exb-client@1.2.0 start: `cross-env NODE_ENV=development webpack --mode development --watch`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the exb-client@1.2.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\Anneley\AppData\Roaming\npm-cache\_logs\2020-12-16T17_09_01_833Z-debug.log
You have to modify `./client/webpack/webpack.common.js`.
In that file, look for `new HappyPack({...})`
You have to manually set the thread count, for example like below.
