Ability to duplicate/copy an element?
248
03-04-2020 06:54 AM
BrianBaldwin
So far, Experience Builder has been great - but there is one enhancement that would help a lot.
Could we get the ability to duplicate elements?
In the example below I have configured the heights, spacing, backgrounds, etc. for the Column and child rows and I want to have the same settings for a column element below it. It would be a great feature if a user could simply 'select' a group of elements and then duplicate or copy it.
Brian Baldwin, Senior Solution Engineer
https://www.linkedin.com/in/baldwinbrian
Reply
DavidMartinez
Hi Brian,
Absolutely, this is on our roadmap.
BrianBaldwin
Thanks so much for the quick reply David Martinez‌! Really looking forward to that feature.
FYI Patrick Huls
Reply
Dunn_Jeremy
Morning David
What's the best way to clone a web app from experience builder so that another user has ownership of it and all it's reference content ?
Regards.
Jeremy.
Reply
DavidMartinez
Hi Jeremy,
If the user is in your organization and you have admin rights you can change the ownership for each item under my content. Another option is to use the python api to use the reassign_to  method to change the other user.   I guess my question is are you looking just to clone or change ownership?  If change ownership you can do the above. If you need to clone there is a clone method in the python API. However, I noticed there are issues when the experience has images. The last time I used that method it had some issues with SVG. You could try that method and see if it works.
Cheers,
David
Reply
