Zoom to result of Search widget action without filtering out other features
1321
06-02-2023 08:57 AM
JasonFitzsimmons
I am new to Experience Builder.
I would like to configure the Search widget to use a Locator search and also a search based on an attribute from a feature layer. I would then like the map to zoom to that location, but without filtering out the other features in the map.
So far I can't do this. When zooming to the locator result , using the 'records created' trigger, all the features of the layer are removed from the map. When using either 'record selection changes' or 'data filtering changes',  triggers for the feature layer search, all but the selected feature are removed from the map.
I want the feature to be selected and zoomed to, but also see all the other features, for both the location and attribute value search.
I am using this documentation page for reference:
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/search-widget.htm
This would be the default behavior in Web AppBuilder.
What am i missing? This seems like it should be pretty simple.
JeffreyThompson2
MVP Frequent Contributor
I believe this is coming in the next update.
https://community.esri.com/t5/arcgis-experience-builder-blog/what-s-coming-in-june-2023/bc-p/1295207
GIS Developer
City of Arlington, Texas
JasonFitzsimmons
thanks- does that mean this can't be done now?
