Symbology: Field label next to my map symbols?
421
03-12-2024 11:18 AM
ReduceReuseRecycle
https://experience.arcgis.com/experience/6937998752b148658765fcdc72ff0ccb#data_s=id%3AdataSource_2-1...
Either in Experience Builder or via Web Map, is it possible to create a symbology where when a POI is selected the symbol will display the name of the site? For example in the map above, clicking a location will display the name of the location next to the symbol? Or if that's not possible, a text box I can anchor anywhere on that map that displays ONLY the name category?
Example: https://imgur.com/a/3VVsXC1
I feel like this was possible in ArcGIS desktop...
Thanks!
JeffreyThompson2
MVP Regular Contributor
One potential solution is to replace your Feature Info Widget with a List Widget that you can then customize to contain all the information that the user needs. Then in the Web Map Viewer customize your popup to only contain the name.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
GIS Developer
ReduceReuseRecycle
Thanks for that Jeffrey. I should just have been using the List Widget the whole time.
