Survey123 Widget in Experience Builder - Why Can't Others See Surveys?
230
03-20-2023 02:07 PM
TSWCD_GIS
I have an experience builder site setup with the Survey123 widget. Survey data is in the map and viewable through other widgets in the site, but the Survey123 widget has the message in the attached image for any organizational account other than my own. The survey, data, maps...everything is shared on the organizational level. Did I miss a setting to make sure other users could view surveys in the widget?
Richard_Purkis
Hi @TSWCD_GIS
Thanks for raising this with us.
From a first glance, it is likely the survey has not been shared to other people. Please refer to the following technical article which guides you through the steps to do this as one of the solutions:
If that doesn't resolve your issue I recommend you reach out to Technical Support.
Hope this helps
TSWCD_GIS
Thanks for the reply @Richard_Purkis , the survey is shared within our org and no one has issues using the survey itself through the Survey123 app. I attached a screenshot of our sharing setup based on that tech article you linked. Sounds like I need to get in contact with tech support.
Richard_Purkis
Hi @TSWCD_GIS
I'm sorry to hear that didn't resolve your issue.
Essentially some part of the survey widget is requesting access to a layer that isn't shared with the respective user. If it isn't the survey target layer itself it must be another layer.
Tech support will be able to dig a little deeper
Hope this helps
