Show local basemap on global app
1243
18
10-21-2021 07:50 AM
GeorgeKhristoforov
In our work we use specialized basemaps and we want them to be available to global users. Now such users have access to a list of all basemaps - not local ones of our organization as we want. We have already seen similar topics on the forum, but a custom widget from one of the topics does not give results. Maybe there is an updated version of it or another solution?
ABishop
MVP Regular Contributor
@GeorgeKhristoforov
Sounds like you want to create a custom basemap gallery for your organization?  Here is a link to a tutorial:
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/custom-basemap-gallery/
Amanda Bishop, GISP
GeorgeKhristoforov
The custom gallery is already there, now we want to make it available to global users without authorization
ABishop
@GeorgeKhristoforov
Then you would just share it Publicly.  If you keep it to the organization level or group level, you would require a login.
To share it publicly, go to the group and click "Settings" tab, then change the group membership and/or designation settings.
Amanda Bishop, GISP
GeorgeKhristoforov
The settings of the group and all base maps are already set as global
ABishop
@GeorgeKhristoforov
Can you show me where you are currently sharing this list with global users?  It may be a setting in your web application.
Amanda Bishop, GISP
GeorgeKhristoforov
Settings of ExB app global too.
When we use the preview in ExB, local maps are displayed in the basemap list, but when the application is published there is a standard list
GeorgeKhristoforov
ABishop
@GeorgeKhristoforov
Go to your organization settings, under the "Map" section, change the Basemap gallery group.  This should change which basemap is used when creating web applications.  Not sure if it will update in your current web application.  Maybe try a new one to test after you change the settings?
Amanda Bishop, GISP
GeorgeKhristoforov
The problem is that local basemaps work only for authorized users, and if you open app globally without authorization in list avelibale only standart basemaps.
