We have recently upgraded from 11.1 to 11.4.
The search & query widgets for experience builder stopped working correctly and I noticed its trying to generate a token based on a token. This creates a 400 error.
Sometimes I'll see a result after a while but mostly it just sits there spinning.
Anybody seen this before?
I have not seen this one. But I suspect it may be related to a known issue. Please answer the following questions:
Thanks for the reply. Its an interesting issue.
It is the version included with Enterprise 11.4, no it doesnt include the add data widget.
A new EXB app with a new Web Map has the same behaviour.
The site uses SAML but it happens with built in users too.
Actually its not specific to the widgets, even just opening the app results in the same behaviour.
We've logged a ticket with Esri.
I'm encountering this same issue using Experience Builder Developer version 1.16, with Enterprise data (map services) and access via SAML (SSO with Okta) in Portal. This issue so far seems to only impact me (the developer of the app) and not the other users of the app. We've deployed it in IIS.
I'm seeing hundreds/thousands of generateToken messages with the same response shared by the OP.
If this is or may be a known issue, I'd be grateful for more details on it. Thanks!
