Public map won't add to the map widget
792
12-04-2019 12:29 PM
Roger_Bannister
Within minutes of playing with the experience builder I hit a road block. I tried to add a map I own that is shared publicly but the Set Data tab in the map widget keeps telling me "No added data can be used." The map contains only a hosted feature layer (also shared publicly) and a base map that uses a combination of vector tiles and imagery. Any pointers to specific content that's not currently supported?
Roger_Bannister
I suspect I know the culprit. The feature layer in that map is shared publicly but with usage limited to specific urls for embedding in our public facing website. It's probably having trouble with it because the url of the experience builder app isn't in the list.
DavidMartinez
Hi Roger,
Can you copy the URL of the public map you're having problems with and post it on this thread, please?
David
Roger_Bannister
Here is a link to the web map's details page.
https://www.arcgis.com/home/item.html?id=e7a1130c534c4e9bb52b48bbbefd677f
Roger_Bannister
Roger_Bannister
David Martinez‌ that was indeed the issue. I added https://experience.arcgis.com/ to the usage limit settings and the map loaded in Experience Builder.
