Print Service Issue
462
9
03-20-2025 05:08 AM
JohnLucotch2
Good Morning,
Has something changed with the Print Widget and custom print services?  As of Enterprise 11.4 and AGOL we are no longer able to use services that worked in Enterprise 11.3,etc.
@TonghuiMing
2 Solutions
ShengdiZhang
Hi, I can reproduce this bug using the Pivot print service in both 11.3 and 11.4. We can confirm that this is a bug in the print widget.
We plan to include a fix in 11.5, which will be released in May.
Please let us know if it works for you.
Shengdi
JohnLucotch2
Amazing!!!  Thank you!!
ShengdiZhang
Hi @JohnLucotch2 ,
Does the error occur when the print widget selects this print service or when the map is printed?
Is there an error message displayed in the network or console in the browser's dev tools?
It would be very helpful if you could share the URL of your print service.
Shengdi
JohnLucotch2
@ShengdiZhang Here you
When we add it into the ExB Print Widget it says Service is not started even though it is.
BolanChen
Hi @JohnLucotch2
Did you fail to add the Print service in ExB Print Widget or did you fail to print? And where did you see the message "Service is not started"?
JohnLucotch2
Hey @BolanChen
After you add the Print GP Service as a Utility in ExB a red message appears in the config of the Print Widget that’s says Service not Started.  It happens in both AGOL and 11.4 Enterprise. It works fine in though in 11.3 Enterprise.
BolanChen
Hi @JohnLucotch2
I can't reproduce this problem on the latest AGOL and 11.4. Can you reproduce this problem on the latest AGOL?
JohnLucotch2
ShengdiZhang
Shengdi
JohnLucotch2
LakshmiRajeevKumar
Have an issue with the print widget. It is not showing any errors in the console or anywhere else but is not producing any openable output.
Please let me know if this is something that can be corrected or is it a bug in the widget!!
