Map Widget Not Showing Organization Basemaps
2998
8
01-25-2021 12:25 PM
by Anonymous User
Not applicable
I've enabled the basemap tool for a web map widget but our organizations basemaps don't show up as choices. I have a basemap group configured for our organization and other web maps/apps show my custom basemaps without issue. I'm seeing this in 10.8.1 portal but not AGO.
by Anonymous User
Not applicable
Just closing the loop, this has been resolved in 10.9 Enterprise
From https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEzNDE5MQ==
BUG-000134191
Synopsis: In ArcGIS Enterprise, the Basemap widget of ArcGIS Experience Builder does not list the custom basemaps defined in the portal.
Bug Number:     BUG-000134191
Submitted:         Sep 29, 2020
Modified:            Mar 23, 2021
Severity:              Medium
Applies To:          ArcGIS Enterprise
Version Found: No Version Found
Prog Language: N/A
Server:                 Windows 10.0 64 Bit
Client:                   Windows 10.0 64 Bit
Database:            N/A
Locale:                  N/A
Status:                  Implemented
Version Fixed:   10.9
SP Fixed:              N/A
by Anonymous User
Not applicable
We're also seeing the same behaviour (Portal 10.8.1). Hopped on here hoping for an answer or workaround.
Did you resolve this? If not, I'll submit a ticket with tech support.
by Anonymous User
Not applicable
I did not find a resolution to this yet.
DaveFullerton
Occasional Contributor III
I am experiencing this problem with the Developer Edition v1.3, not in Preview, but when I deploy it to the production server.
by Anonymous User
Not applicable
Just following up with this.
It's a known bug (BUG-000134191) and is in the current product plan for Experience Builder, so hopefully resolved in a future release soon.
by Anonymous User
Not applicable
Thank you for following up. You beat me to the Tech Support call.
Grant-S-Carroll
I experienced the same using ExB Dev Edition against Enterprise. I worked around it by creating my own basemap widget which will only pull in the organisation basemaps. Code attached if anyone wants it, it s basically the JS API basemap widget with a call to get the organisation basemaps, have not tested it against AGOL.
GeorgeKhristoforov
Hello!
Faced with the same problem. Unfortunately using your widget didn't work for us. Maybe you have a new version of the widget? Or this version workable now?
Maybe we are installing it incorrectly...
by Anonymous User
Not applicable
BUG-000134191
Severity:              Medium
Prog Language: N/A
Database:            N/A
Locale:                  N/A
Status:                  Implemented
Version Fixed:   10.9
SP Fixed:              N/A
