Log out of Custom Experience Builder Application
546
11-01-2020 01:30 PM
Grant-S-Carroll
Hi All
I'm building a custom app using experience builder one of the requirements is that a user should be able to log out of the application. I'm struggling however to work out how to do this.
I see there is a session manger, and I have tried calling signOut on that, but if I refresh my page again I am still logged in, I have also tried destroying the exb_auth cookie manually and trying to invalidate the token.
Any guidance on this would be greatly appreciated.
Cheers
JunshanLiu
Occasional Contributor III
I think call `SessionManager.getInstance().singOut()` should work, can you try the latest version (1.2)?
Grant-S-Carroll
Thanks for the update, I ended up using the esriId.destroyCredentials(). Out of interest though, if we wanted to create a custom login screen how would we go about doing that? Should we be using the session manager? I've just noticed that if I use esriId, then it will login and I can then change the page, but then when it tries to load a webmap it prompts for login again, so I'm thinking that the token I have created with esirId is outside the Experience Builder system.
So I'm thinking that session manager is the way to go? Would that be correct?
Ranga_Tolapi
I do not find any developer samples for SessionManager. Would like to implement silent Sign-in (user shouldn't get sign-in popup) for Webmap with the secured layers, any advise on how this can be implemented using SessionManager or any other possible way please.
Thank you.
