Journey Template
148
06-07-2021 07:37 AM
Sburnh
I have used the journey template with the aim of achieving something along the lines of the following:
https://experience.arcgis.com/experience/df36d88209d9458bbd5ecf85515de827/?data_id=dataSource_1-Silv...
However, I have found a couple of limitations with this approach:
  • Adding an embedded hyperlink that will change based on the bookmark/ location
  • Ability to click on a point on the map and it take you to the relevant bookmark
Can anyone suggest any solutions? I don't want to use the developer edition, but simple code changes are fine.
DylanTrerise_EsriCanada
Hi @Sburnh, for your first point you could connect to data in the Text widget. This is assuming you have the hyperlink stored in an attribute for that point.
For your second point, could you clarify what you would like the app to do beyond what your linked example already does?
