Is there a way to change units on "Scale bar" tool in Map Widget?
2260
06-15-2020 10:26 AM
DorothyFriday
My scale bar is in miles on my source map, but showing up in km when added as map widget in XB. Don't see any controls for the scale bar tool other than "Scale bar" on/off.
DavidMartinez
Hi Dorothy,
Currently, we are only returning the unit in metric. I added an issue to support non-metric as well.
David
DorothyFriday
Got it, thank you David!
AndyWells
I would like to also suggest the ability to move the scale bar around the map, change the format, allow additional scalebars, and maybe the option to use a ratio (1:###) instead of a scalebar.
